| Command | Description |
| ap-id (iot-device-type-imagotag-policy) | Configures an Access Point (AP) ID, allowing the SES-Imagotag server to identify individual Imagotag-enabled ExtremeWireless WiNG APs. |
| channel (iot-device-type-imagotag-policy) | Configures the channel assigned for ESL communicator to tag communication in the 2.4 GHz band |
| enable (iot-device-type-imagotag-policy) | Enables the ESL communicator |
| fcc-mode (iot-device-type-imagotag-policy) | Enables the FCC compatibility mode on the ESL communicator |
| output-power (iot-device-type-imagotag-policy) | Configures the maximum output power for the ESL communicator |
| payload-size (iot-device-type-imagotag-policy) | Configures the maximum payload size in packets exchanged between ESL communicator and tags |
Configures the ESL SES-Imagotag server‘s hostname or IP address |
| ssl (iot-device-type-imagotag-policy) | Enables SSL (Secure Socket Layer) encryption mode of communication between the AP and the SES-imagotag server. |
| window-size (iot-device-type-imagotag-policy) | Configures the transmission window size for messages exchanged between ESL communicator and tags. |
| no (iot-device-type-imagotag-policy) | Reverts this IoT Device-Type Imagotag policy settings to default values |
